Install second batteyr
It's best to consult with an audio system professional or seek advice from reliable installation guides for optimal setup.
I'd run the 0-gauge power wire from the front battery positive terminal, not directly off the alternator.
The battery is your main power source/storage point, while the alternator keeps the battery charged and supplies current while the engine is running. Run your 0-gauge from the battery to your amp(s), and put the proper fuse as close to the battery as possible.
I'd also make sure your grounds are upgraded to match the power wire—especially battery-to-chassis, engine-to-chassis, and your amplifier ground.
You can incorporate the alternator into a properly designed high-output electrical system, but for a normal car-audio installation, battery → fuse → 0-gauge power wire → amp is the way I'd go.
randy hagan
CarAudio.com Recruit
randy hagan
florida
Bumpbump
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
