If you had the money: XXX or Magnum D2
Which setup should I go for?
  • XXX with a BX1500d
    Votes: 32 84.2%
  • Magnum D2 with a BP1200.1
    Votes: 6 15.8%
  • Total voters
    38
aarunt1
:D
Hello,
I have a question that I really need answered. If you had the money would you get a XXX with a BX1500d or a Magnum D2 with a BP1200.1? I already have a BP1200.1 and was thinking to get the XXX and possibly trading/selling my BP1200.1 for a BX1500d. Do you think I should stick with my BP1200.1 and get the Mag D2 or go with the XXX and get the BX1500d. I really like the looks of the XXX and all RE woofers. Correct me if I'm wrong though, I read the Mag is more efficient. Also, what is this XLB2 motor that the XXX uses and what are its advantages? What motor does the Mag use? Also, would I tell a difference in the way the 2 sounded? The XXX would have 300 more watts going to it.
Please help me out.
Thanks
XXX15 and bx1500d, i was settled on this setup, after a very long comparison to nearly every super sub i could think of. I was going for a pair of each.
I finally made up my mind and went with a pair of Eclipse TI15 and an orion 2500d. Cost me less than the pair of 15XXX and two bx1500d. will save me some room in my ride also.
Ye I really like the XXX and it doesn't cost much more for the XXX12 than the Mag. Seems like mst people port their subs but I thnk i'll just gonna the XXX in my 1.2ft^3 sealed box. I think that should do fine. If not I will have to build my own box. I always wanted to try a ported box.
Seems like alot of u posters have/want the RE SX. What is so great abou the SX. I just heard it gets louder than the XXX at 1200w and it is 60spl/40sq. Isn't the Mag an all-around better sub than the SX also?
XXX, better at everything then the Magnum, dont get me wrong its a freakin awsome sub... but XXX is better
According to you..................... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
if i was going to go sealed i'm not sure. I've had RE subs before and they seem to like ported a lot more than sealed (as most subs do)..
i would go with the XXX just because of my experience w/ the quality of the subs, but the Magnum is nasty, and if i was short on room i'd go with the magnum sealed.
Hmm. I could always build my own box. I have a 1998 Dodge Neon and the trunk isnt huge but its a pretty decent size and the trunk is emtpy besides having my box in there.
i bet you have at least 5 cubes to work with back there.
I bet the XXX 15 would be happy in a 3.5 cube box tuned to 35hz. I had my HC in a 5.5 cube box tuned to 38 and it SLAMMED. RE specs out the box to be a little bit smaller than what i had my HC in, it would have been a lot cleaner in the smaller box too.
go to re's website http://www.respl.com and click on the tech button, i think it will point you in the right direction for boxes for each of their subs.
But.. right now i am thinking about getting 2 magnum 12"s and putting each of them in a big ass box w/ 800 watts per sub for fun... both of them look like badass subs, and it is going to be a tough decision, as the magnum will cost less and still sound incredible, but the xxx might have a little more output.
Hmm. Seems like I'll probably go with the XXX15. 1500 watts should be enough, even tho it has 1600w rms right? Also, I don't listen to rap, I listen to hardcore/emo-core/alternative (Stuff with alot of fast bassdrums). So the XXX should be good for that right?
aarunt1
:D
aarunt1
Ridgecrest, CA
linksyz
Emanuel Rodriguez
    Apr 19, 2025
Emanuel Rodriguez
    Apr 19, 2025
