IDQ 12, Arc X2V2 or...? SQ focused daily driver sub
Looking to put 300w - 500w (depending on 1 or 2 Ohm load) into a single 12" in my SUV. Listen to mostly rock/punk with a bit of rap and hip hop (at a moderate volume), so I'm not looking to shake the walls down.
I'll be getting a box built to spec, or picking up a pre-built if one is available that fits the size. in the case of the 3 listed, Audiointensity.com has boxes built to spec on their site. ideally I'd want as small a sealed box as possible.
Been looking at the IDQ12 or the Arc X2V2, possibly the Arc series 12. Anyone have any opinions or better suggestions?
When selecting a subwoofer for your SUV, especially with a power range of 300W - 500W and your musical preferences, both the IDQ12 and the Arc X2V2 are strong contenders. Let’s break down both options and consider some additional suggestions.
### IDQ12
  • Sound Quality: The Image Dynamics IDQ series is well-regarded for its excellent sound quality. It handles a wide range of frequencies exceptionally well, making it great for rock and punk as well as rap and hip-hop.
  • Power Handling: The IDQ12 is designed to handle around 300-600 watts RMS, making it versatile for your power needs.
  • Enclosure: It performs well in both sealed and ported enclosures, but for your listening preferences, a sealed box might provide tighter bass, which is often preferred for rock and punk music.
### Arc X2V2
  • Sound Quality: The Arc Audio X2 series is also known for its clarity and performance, especially in smaller enclosures.
  • Power Handling: Similar to the IDQ12, the X2V2 can handle up to around 600 watts RMS, making it suitable for your moderate volume settings.
  • Design: It’s typically designed for a compact fit, which is helpful in SUVs where space might be limited.
### Additional Suggestions
1. JL Audio 12W3v3: This subwoofer is renowned for its accuracy and punchy bass response, making it a solid choice for diverse genres.
2. Rockford Fosgate P3D4-12: This sub offers a lot of value, providing a good balance of performance and price with flexibility in installation.
3. Kicker 44DCWR122: Robust and capable of delivering solid bass, this sub can also perform well across different music styles.
### Installation Tips
  • Enclosure Type: For the music styles you're listening to, I recommend a sealed enclosure for tight bass. Use the manufacturer's guidelines for the ideal volume.
  • Wiring: Ensure your sub is wired correctly to match the impedance (1 or 2 ohms) you want to run it at for optimal power delivery from your amplifier.
  • Power Supply: Make sure your amplifier can deliver clean power without distortion at the power ratings you’re aiming for, especially at the peak volume.
### Conclusion
Both the IDQ12 and Arc X2V2 are excellent choices, and your decision may come down to personal preference regarding sound signature and fit. The additional suggestions might provide alternatives worth considering.
Feel free to provide any further specifications or preferences regarding enclosures, and I’d be happy to refine my recommendations. Also, I encourage other members to chime in with their thoughts or experiences!
Arc Audio has great subs, but I would lean towards the ID subs. If you are start talking about amps, the Arc amps are awesome!
With the subs, either route you go, you will not be disappointed.
entropism
entropism
Scotch Plains, NJ
Old_Slapper
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
