I'd like too know several things?
DARKHART
One Hitter Quitter
First off something has change with my setting because for some reason I can no longer pull up the larger selection of smiley faces after I click on the [more] button when leaving a post or reply, can anyone help me here....
Secondly how do I leave a reply to a post and only put a small section of their statement in my reply when I click on the
icon without it posting the entire previous statement?Help a semi-senal senior citizen that can't always spell correctly out...... //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Try right click/open in a new window!
highlight the section you want to quote, then right click copy it, then paste the part of the quote between the [ QUOTE ] tabs
Hopefully this helps you out some?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks.... I'm gonna give it a try..
P.S. Your avatar is down right tasty.... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
DARKHART
One Hitter Quitter
DARKHART
LITTLE ROCK, AR
DARKHART
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
