I picked up a 1001bd amp, and one Power HX2 12" sub. Keep in mind these are both last years models. I was wondering what the best way to wire it up is? Is it going to be not putting out as much because it's only going to one sub? Or should I get a second sub, in order to get the full power out of the amp, going to each sub.
These are the stats on the amp.
Per channel power
500 W X 1 @ 4 Ohms RMS
1000 W X 1 @ 2 Ohms RMS
Total power
RMS 500 Watts RMS
So does that mean that in the per channel power the 1000w @ 2 ohms is peak or RMS? Because if that is rms, then doesn't that mean that I can hook it up to my one dual 2ohm sub and give it 1000w rms?
I'm thinking I got burned when I bought the 1001bd amp with the hx2, since there is no way to make the amp give out the power that the sub wants.
Per channel power
Total power
RMS 500 Watts RMS
