I need help in 30 minutes or less
So long as it is not ran below 4 ohms, you should not have many problems.
While Jensen normally has been Entry-Level/Affordable, thier quality has been dramatically increasing recently.
I would say it is definately a good bang for the buck amp.
take it easy,
-zane
take it easy,
-zane
What's wrong with going under 4 ohms? I just bought a dual voice coil 4 ohm speaker that I planned on using this amp with and it's 2 ohm.
Thanks
The amp will not push it very well. It may push it, but it may burn up sooner than you like. I do not like Jensen, but it is your choice. They say they are 2 Ohm stable, but I would not believe them.
I think he is bidding on it with Ebay and wants to know if it is worth the money.
I already have the amp and bought the speaker thinking it is stable at 2ohm. Can I keep the bass boost down and the levels in the middle somewhere and keep it alive? I don't really have the money to go get an amp.. but maybe in a few weeks. Just don't want to blow this amp up.. it worked well in my old car on 2 speakers!!
Thanks for all the help!!
You aren't supposed to use bass boost on a sub, just set the lpf for around 75-90 hz and turn the gains up until it gets loud enough for you.
Why would they put the bass boost knob on the amps then? It is my understanding that it is better to keep the gains a little lower and adjust the b.b. up as needed to avoid clipping issues.
buchel
Veteran n00b
buchel
Ontario, Canada
tplaya07
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
