helotaxi
Kilroy was Here
There are several alignments used when designing a ported enclosure. They use a different volume and tuning to achieve a different goal with the speaker, ie smooth frequency response, minimal group delay, best efficiency, etc...
You cannot make a fair comparison between two subs in a ported box using the same box for each, unless they want the same box for the same alignment (very rare). Each sub has its optimal enclosure size and tuning. Using something other than that will keep the sub from performing as well as it can and will not allow for a fair assessment of its capability or quality. It is possible that the DD sub in your comparison was better suited to the enclosure that you tested them in than the XXX. It is LIKELY that the enclosure was far from optimal for either and that putting them both in their optimal enclosure will yield far better performance from both of them.
