ifandorbuts
after much mind changing and many good and bad examples, the final prototype arrived and all is well. I have signed off on it and have authorized production. I managed to get
here are the basic specs for the final version of our entry level Vibration Mat, Damplifier:
59 mil thick butyl/mastic compound
3 mil aluminum foil
installed weight of .39 lbs per sq foot
450+ degree F. Tollerance to heat without failure
sheet size 32" x 18" die cut
Damplifier Pro Prototype should arrive this week. If all goes well specs will be similar to:
78 mil thick butyl/mastic compound
4 mil aluminum foil
Installed weight of .50 lbs per sq foot
475+ degree F. Tollerance to heat without failure
Both products will be offered in kit sizes like:
Speaker Kit 4 sq feet
Door Kit 16 sq feet
Trunk Kit 28 sq feet
Bulk kit 40 sq feet
compare the heat tollerance of Damplifier, 450 f. to that other popular brands
Dynamat extreme 300
Brown Bread 293
bquiet extreme 230
Fatmat 200
peel and seal 150
It has taken a lot of work to get as far as we have, and appreciate everyones patience as we perfect out line of sound deadening. Thanks for all of your support and suggestions.
ANT
3 mil aluminum foil
4 mil aluminum foil
Door Kit 16 sq feet
Bulk kit 40 sq feet
Dynamat extreme 300
Brown Bread 293
bquiet extreme 230
Fatmat 200
peel and seal 150
ANT
