Humm noise - rockford r2-300x4 amp
  • 2
Sito
Israel
Hi,
Had a specialist install this amp in my car(electric Car - ioniq 5).
The setup is high level 4 Channel amp.
After the installation, i hear hummiing sound from speakers even when the audio system is turned off, it only disappears when I lower the gain to minimum in amp.
I tried disconnecting the amp input that comes from HUD but the noise still remains.
I also checked the ground connection to chasis(checked no coating on screw as well) still didnt help.
Can any one give me idea how can I proceed from here?
Thanks
Does this mean you disconnected the RCAs that are on the amp? If yes, then the amp is the issue. What make and model is it? Is it connected with an Line Output Converter or RCAs from the back of the radio?
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
Sito
Sito
Israel
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
