How's it going so I'm new at installing car audio stuff so I was wondering if I can get some help so I don't blow my speakers or mess my amp
  • Participants list
Gpguy1986
So I'm new at this car audio installation stuff but I have a power acustic 2500 watt mono single channel amp and I have a Alpine swr-12D4 dual voice coil 4 ohm 12 inch subwoofer and I have a memphis mb1224 dual voice coil 12 inch subwoofer and it can be hooked up either as a 2 ohm or 4 ohm and I was hoping to figure out how I can hook this up all together and not mess up my new speakers or my amp
The companies that use "max or peak power" as the rating on the am are living in another world or something.
In order to get that 2500 watts from that amp all the planets have to be perfectly aligned, the world has to be at peace, the ice caps have to replenish themselves and the Titanic has to sail into New York harbour
If it is the Razor one then the numbers are to equal what it dyno'd at
The real numbers for it are 450 watts @ 4 ohms and 650 watts @ 2 ohms
It is not one ohm stable
The alpine sub is dual 4 and the rms on it is 750 watts
So 750 watts @ 2 ohms is what it's capable of
The memphis is dual 4 or dual 2 but dual 2 will put the final load at 1 ohm which your amp can't handle
So 500 watts @ 2 ohms is what it is capable of
As mentioned above you can't mix subs, it causes all kinds of problems and will sound like ****
If it was me I would go with the alpine in a ported box
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
Now you're annoying me because you are attacking me personally without addressing anything I've said. Show me a single post I've made that's...
20
4K
Gpguy1986
Gpguy1986
Grants Pass
Kickstand
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
