How should I cover my door pods?
What should I cover the pods in?
  • Vinyl (dark grey)
    Votes: 2 33.3%
  • Carpet (dark grey)
    Votes: 1 16.7%
  • Other (please explain in post)
    Votes: 3 50.0%
  • Total voters
    6
I know, I'm just giving you a hard time. I say you blend it in the with door panel or goto an automotive part store or your local parts dept and get some replacement material for the door to conver it with, that way it will look stock.
I wish it were that easy. If it was I wouldn't be asking. The door panel is not covered with anything. It is textured plastic. I could just cover the whole door, but then I would have to cut out the insert sections and glue them back in place once I am done. PITA.
If it is textured plastic, can you not take a mold of the texture and make some sort of rubberized plastic replica of it to stretch over your pods? Ehhh... I guess that wouldn't be too easy either.
That cloth like covering on your plastic molded pocket looks like it would be marginally easy to find a good matching fabric to cover the pods with, and that might not look so bad //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Also, what about mussing around with artist style texturing, like painting and then blotting the wet paint with crinkled aluminum foil/saran wrap etc? That might also yield a result you are looking for.
The fabric on the molded in pocket is automotive carpet. That is the main reason I included that as one of the choices.
I might be able to make kind of like an embossing stamp of the texture and then press it into the bondo as it starts to set up, but I am not confident that it would look very good.
if you mixed the bondo so that it took a long time to set, and made a mold of the plastic on your door from something, and then pressed that against some semi-cured bondo, and used a hobby knife to connect lines, I could see it working, but it would be extremly tedious. Then again, it would look totally stock and one of a kind. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Got to thinking (dangerous, I know), My car has a carbon fiber look leather wrapped steering wheel and shifter boot from the factory. If I could find a source for that leather, it should ift right in with the interior of the car. I can find vinyl with the same pattern but only in black, not charcoal. Not sure it would look right if the color is off. What do you guys think?
I think it's a good idea.
However, I'd definitely see to matching the color.
- Steve
helotaxi
Kilroy was Here
helotaxi
South Central (New Mexico that is...)
Mark_ab
JayBoogie808
    Apr 17, 2025
JayBoogie808
    Apr 17, 2025
