How long can I listen before the battery dies?
sumone
Midwest
Okay, this has happened a lot recently. I know it's a pretty bad idea to sit with the car off and the radio on, when you have an amp hooked up.
Today I got stranded while waiting for a friend that took forever to come out the house because my car wouldn't start and needed a jump. This isn't the first time.
The thing is, it had to have been no less than 20 minutes (and I had been actively driving for at least half an hour before I parked) that I was sitting there, waiting for her. And let me tell you this was embarassing as hell - as I had music blasting and then went to turn the car on and....well no start.
Does this mean I
1) have a bad (or going-bad) battery,
2) something's wrong with the alternator,
3) or something else?
don't have dimming problems. this is just a 65Wx4 channel amp.
I don't think 20 minutes of listening would do it based on the equipment you have. I think it's the battery. How old is it? Batteries typically need replacement every 5 years or so depending on the situation.
More than likely it wasn't caused by the amplifier, even it it was at 300watts. 1000 watts or so is a whole another story.
You said "it needed jumped", so I'm assuming you had the car jumper-stated and it then started? Was the car cranking/turning over when you tried to start it? If so, you most likely have a dead battery; like sungwei said, typically every 5 years. Unless you have the wrong battery for your vehicle, then it can go bad in as little as a year; I've even heard 3 months. It could also be bad cables, starter relay, or even the starter itself, but usually if its the starter there's no sound. Speaking of this being a car audio board, your cables are connected securely right? Loose battery cables can cause starting problems, and even degrade engine power.
It has to be (at least in some way directly or indirectly be caused by) the amplifier cause when I didn't have an amp, I would always listen in the car with the engine off for more than 20 minutes at a time.
I needed a jump. I guess that's what you (or let me say "I") call it when you need to hook the cables up between your battery and a good battery of another car.
Basically when I tried to turn the car on, after the chimes and beeps and stuff when I hit the "on" level of the key, and then keep turning so that the ignition would ignite, it just stops. No cranking or sounds that would cause you to say like "come on...come on..." it just stops and you don't hear anything (in terms of the engine trying to start).
Car is a 2000 malibu, so I'm guess it came out in '99...looks like I am at the 5 year mark.
Pretty sure stuff is hooked up right/secure; otherwise I wouldn't have been able to drive immediately prior to parking.
Beat your battery up and you will shorten its life. Go to Pep-boys or some other joint that will do a free battery check and find out if it really is going out; if the battery is fine (Doubt it), get your charging system checked. Shorter capacity, and not holding a charge are signs a battery is on its way out. Also, make sure your battery terminals are clean---no white residue on the positive terminal; it can cause your battery to not re-charge correctly if it's bad enough.
Prime time to scrape up some extra cash for an Optima Yellow top!
Good luck with it. Later.
"If the car turned over then you have a bad battery" ??????????????? I dont get this... My battery was at six volts once (bad alt) and the engine was still firing. Starting the car is what requires all the amps from the battery.
Get an upgraded battery. I have a red top,and have had my 50x4 amp playing all day bout half tilt,for 4 hrs or so(beggining of school until lunch time...accident) and the car started at the end of the day.
Upgrade your battery,and you should be able to chill for about 2 hrs no prob.
Were you using the AC?
In the $600 range I like my stereo integrity speakers so far Tm65 midbass $399 m25 tweeters $199
8
What is your voltage doing when you hard accelerate or brake? The civic have a complex alt control that shuts the alt down to save fuel. Its...
7
The net volume looks more like 1.5 cubic feet. The rest is a labyrinth slot port. If only the exit port is that wide then I wonder if it is more...
18
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
950
sumone
sumone
Midwest
sumone
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
