how do get 2 ohm load.
  • Thread starter Ingnorance
  • Live activity
  • Replies 1
  • Views 2K
I
Ingnorance
Guest
To get a 2ohm load on a 4ohm DVC sub with a mono-block amp (has two outputs), do I wire the positive and negative of one output on the amp to the negative and pos. of one voice coil, then wire the remaining neg/pos output on the amp to the remaining neg/pos of the voice coil? (Also, just to make sure, a two-ohm load will be best, right?)
amp out(1) + to VC(1) +
amp out(1) - to VC(1) -
amp out(2) + to VC(2) +
amp out(2) - to VC(2) -
the above will give you a 2 ohm load with the equipment you described and is the best way to connect it!
Guest
imral3
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
