FEATURED Hooptie Scion TC build
Alrighty. Email from Sam.
"We upgraded our rotor so it would convine better with our stator. It will ship today
Regards,"
Lowered the coilovers a bit more today. Looks perfect now.
Lmao I'm down the road from them trust my whole team runs them
Only thing I gotta do is bypass the ELD in the car. Gotta love Honda 😒. Basically what that does is under low or no load going through the fuse box, it will drop the voltage to battery float (12-12.4v). It will not bring voltage to 14.3 ish unless a load is detected on the ELD in the fuse box (like the head lights being on). You hook up direct to the battery the amp load won’t be detected and you will be stuck many times at that 12-12.4v. So I gotta bypass that which is easy.
Yeah it's a b?!3
I broke something in the box. Thinking a window brace. Terrible rattle above 40hz. Also thinking about cutting down the port to raise tuning. I'm tuned to 28hz and it will play 20hz full tilt no problem and moves alot of air but I don't listen to music that low. Lowest songs I play are around 26hz.
Other than that I have been beating the hell out of these cheap subs and they have been very impressive.
Alternator has been fantastic.
40ah Yinlong has been fantastic. So glad I went lithium.
I have a 2012 Toyota 86 (Australia), with the standard factory fitted head unit. It has served me well over the years. All of a sudden the...
16
421
755
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
666
Team Lethal Pressure
Central FL
    Apr 13, 2024
    Apr 13, 2024
