Hooked Ground to + and + to Ground...but
smmmokin
Canada
So the amp is a JX10001d. Such a dumb thing to do(No bad smell came from the unit. Took about a minute to realize and unplug it) But the odd thing is with it wired correctly now the power light comes on the amp and everything seems fine. No fuses got blown anywhere and when the vehicle is turned off the amp switches to protect mode. Turn vehicle on it switches to power. Tried everything but can't get any sound to a sub(Tried multiple). I'm confused because the amp still powers on. Could something inside the amp be messed up? Is it safe to open it up and look without worrying about a shock? Cost so much money so I'm sad and depressed and hope one of you have a magical solution. Thanks for any info.
I will add I've been using the amp and sub for a long time. Never has issues in the past. Needed to clean out my truck so unhooked and pulled it all out. RCA cable to/from the deck is hooked up, everything seems good.
The inside of this thing looks mint. What exactly would be wrong with it? Nothing is burnt or smells burnt. I don't get it. I've seen people say something inside the amp gets fried when they do what I did and there could be smoke or smell but not in this case. Any ideas?
18667
At the top of the board by the power/ground inputs, it looks like the Q5 and Q6 transistors are toasted and have black soot. The Q6 transistor's middle leg is broken, too. I'm not an expert, just my observation.
hmmm. I'd like to look underneath. I'm scared to touch it in case its holding a charge. You have any idea if it'd be safe to start touching the board? Either way I appreciate the input. You're nice!!
How did you miss that? 💀 View attachment 18669
:( I plugged positive to ground. I'm just the kind of person who would miss that lol. Bought the truck used thats my only defense. Even tho there is clearly a blue cable running from the positive battery terminal.
This really *****. Thanks people. Appreciate your time. Meanwhile my friend gave me a cheap Sony xplode 1000watt amp and another buddy gave me a type r 15". Amp overheats in 10 minutes. So thats real good. But man that thing pounds. Good times. Good times.
Meh it happens. You can message an amp repair place and see if they can give you a round about quote for repair. Might not be worth it though. Shane Ekstrom in Florida does good work but shipping would probably be pretty costly.
Appreciate it. I'll check around see if there's anyone around here. Might as well. Thanks again!
From now on...check, double check, and triple check your connections, before installing your fuse! It pays to be meticulous, when installing sensitive gear.
Looking at the inside....that really don’t look like too hard of a fix, if you can get your hands on the Right components.
I'm guessing that's what it is. There's not a lot of room back there.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
Yeah I saw a lot of that when doing those installs as we also did surround sound system wiring as well. I always ended up being the doing it as...
smmmokin
smmmokin
Canada
Slo_Ride
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
