high pitch noise when car is turned on
  • 2
mojojojo
aus
Hi, when im using the car in accessory mode there are no high pitched noises but as soon as i turn the key to ON or START the car i can hear this high pitch noise from back speakers, i had disconnected the cables from the amplifer and it disappeared but came back once i plugged it back in. I have no clue on how i am able to fix this, anyone have ideas?
AMP : Pioneer GM-A4604
Speaker : Pioneer TS-A6965S
Car : 2011 Lancer
Clean your ground for the pioneer amplifier. Most likely a ground loop. Other possibilities are a bad headunit ground or an alternator on the way out.
Decibels are a measurement how loud something is...it's not the frequency of hearing...
19
Unfortunately barly someone does these things in my country, and the ones that do, makes it so expensive to test it or even fix it that testing it...
With the new info that factory amp is still connected, Coolhand20th's original assesment may be right. Radio may be causing the noise. I would...
14
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
418
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
404
mojojojo
mojojojo
aus
wew lad
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
