Hifonics XX-Maxximus
Hydrastas
Ok, i'm tired of messing with two amps so i've decided to save up and get one of these. $3500 for an amp is a little expensive but oh well. I'm thinking about getting two solo x 18s for this amp would that work out ok? Atm i have a stock alty, stock wiring under the hood and a run of 4 ga to the trunk. lol where should i start to be able to give this thing the current it will need?
i've got an 01 grand am, i'd be willing to lose the ac but idk about the heater. How many alts would you suggest getting? Would 4 200amp alts be ok? and how many batteries would be best?
listen man....if you have the willpower and the money then you can do this. if you aren't very serious about getting it doe etierh stop now, or spend thousands more at a shop to have them do it..... for getting new alty's and haveing them put multiple ones in then yes, it'll be hellaciously exspensive if you have a shop do it.
you need probly 2 high output altys. at least 2 runs of 1/0awg., id say like at least 3 big batteries (maybe 2 or 3 kenetic 2400's). enough space for a freaking huuuge box for those 2 solo x 18's. in fact wall those off if you can, if not then make a good box.
if you have the want to make this work, you an do it. get help, and get it done right. if done right, this will pound, pound pound pound
2 300a alts would make a start
my Goliath uses 500a of fusing and a maxximus is 2 of them
i doubt 2 runs of 1/0 is enough, 3-4 would do, the amp has 4 1/0 power hookups
a good bit of batts in the back
**please dont try this**
you are jumping into the deep end of the pool without knowing how to swim //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
it will just end up a mess, try little bit smaller steps, you say 3500 for the amp, your looking at close to that on wiring and electrical, plus 2 solo x's and box
trust me, way over your head
too much too for a little grand am
but if you want to do it better start selling drugs and ************...
Its the truth.
either way, IMO, if someone is asking what they will need to run THAT an amp, they need not attempt that amp, ESPECIALLY in this case
right,you can do it for comps only like me,but everyday no way,i only use 1 of my amps daily,and i got a slide in port also for daily,i mean realistically i dont think //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif even if you had 3 alts and 3 batts you could run it daily,if you did you would have to turn down the amp so much so it wouldnt tear up the subs on music,that you would been better just to get 3 or 4k in the first place.
Hydrastas
Hydrastas
NE ks
B_Campbell
