hifonics brutus bx2200d?
78nova
XXX
well i was searching around the internet for prices on bx1500d's and then i kept on running on to this amp, and that its coming out this spring. so i was wondering should i just hold off getting the bx1500ds and get a couple of these. also i think it does 2200w rms at 1 ohm. //content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif
thanks
If you got the right load impedance, give it shot. Since it hasn't come out yet, nobody can give you impedances. I have a brutus, it's a good amp, cheap and pretty efficent.
BX1500D's are around $280 shipped off of eBay. That will give your two XXX's 1500w each.
A BX2200D is priced at almost $1100 everywhere that I have seen it, and will only give each sub 1100w RMS.
I do not know much else on this topic, but I loved my BX1500D. Your call.
T.J.
ive heard caps are totally necesarry for that much power... that true?
that is one of those topics where it just depends on who you talk to. There have been lots of threads on the use of caps. I personily think they are no good and can even be bad for your system but that is just my view. Instead of worrying about a cap look into the big 3 wire, battery, and alt. Worry about them long b/4 you worry about a cap.
Jon
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
78nova
XXX
78nova
Bovina, Texas
kickerlivinloud
spokey9
    Jul 17, 2024
1aespinoza
    Jul 15, 2024
