help with tuning
the displacement is .3 total for the subs, the brand is not needed for a box tuning.
there is also another box i need tuning info on, the specs are,...
box 5.5 internal
port 2.444 cubes 86.625sq.in"
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
5
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
I may have missed it, but do you have sound deadener on the doors? If not that could be why you're lacking midbass.
994
Do you intend to drive around playing test tones? If your intention is to play music, you should be using music you intend to play to dial in...
9
akadj
akadj
Edmonton Alberta CANADA
boister77
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
