Help with port dimensions
Farside
Hey there //content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif
I have a 12" Apline type R sub, I've been reading various DIY ported box formulas, including those on Loudspeakers101.com. By entering my Subs parameters I get Vb=1.912 ft^3, Fb=27.1 Hz
I get a minimum port diameter of 5"? does this seem too large? If I use this value of port diameter then the length has to be 34"??? how do you fit that into a box of only 1.91 ft^3?
I know if I go with a 4" port then the required port length begins to drop, but wont i get too much air noise? should I use a higher Fb then the one that was calculated? say 30 HZ??
Any help to clear this up for would be greatly appreciated, thanks.
thanks for the reply...
my sub is a SWR-1221 and I'm powering it with a Coustic 400 WRMS amp, if that changes anything.
One more question....can a port stick out the side of the box if there isnt room for it inside the box?
thanks
Hey thanks again,
I've decided to use a Vb=1.68 ft^3 box (internal volume not including sub & port displacement, I assume thats what Vb is) with a 4" port 22" long Tuned to 28.7 Hz.
Still cant figure out that dam minimum port diameter calculation :blow_up: , but oh well 4" sounds resonable.
My question is now that I have all my dimensions to work with, what is the minimum distance that the port can be placed to a wall inside the box and the Sub?
Is there a minimum distance that the sub must be from the walls as well or is this just a practical measure?
ok thanks for all the help and bearing with me since I'm a nubie at this,
Using WinISD
Volume=1.68 ft^3 (Is this Vb in WinISD?)
Tuning Freq=27.4
4" dia port @ 24.5" long for two free ends (even with an 90deg elbow I think it'll be a tight squeeze) or 24" for one flanged end.
The port air velocity peaks at 110 ft/s ( 33.5 m/s) @ 22.95 Hz with a Max input signal of 400W. My amp puts out 400 Watts RMS so at max power out the air velocity is getting close to 35 m/s.
The SWR-1221 is rated at 300 Watts RMS so air velocity at 300W peaks at 95.3 f/s or 29 m/s @ 22.5 Hz.
You say as long as I stay below 35m/s I shouldnt get alot of air noise, will I notice any at 33m/s? I guess as long as I dont crank the **** out of my system then I wont be near 35m/s and air noise shouldnt be a problem right?
If I'm using a Vb=1.68 ft^3, Vsub=0.128 ft^3 and Vport=0.196 ft^3 then my total (Gross) box volume must be 2.004 ft^3
So this means (H-1.5)*(W-1.5)*(L-1.5)=2.004 ft^3 right? (using 3/4" MDF)
on winISD they dont have any alpine subwoofers? i have two alpine 12 " SWR-1241D
what is similar two them their or what do i do?
i figured out how to creat one but i only know about half the specs
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
I'm trying to put a 2018 HU in my 2017. Both have all the bells and whistles. I have researched both electrical diagrams and think I'm 99.3% done...
Farside
Farside
Vancouver
mykeys
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
