Help With My Decision
idiot
I’m in the process of deciding upon amps for my system. Below is a list of the possibilities I’ve found (though if there are another pair of amps that can be gotten for around $400, feel free to mention them). Some of these are ebay prices.
My components will be Focal 165 K2P. Power handling: 100W-200W.
My sub is a small ID ID8 V.3. Power handling: 300W.
My question: how would you rank the pairs (or mixtures of the pairs, since I simply separated them by brand) by your opinion of which are best? Avionixx only lists two models available in their store, and the 400.2 isn’t one of them. Some people have expressed disgust with the PCX line from PPI. And though everyone raves about Zapco, I’m wary of their bottom-line products. The Orions are just big, and I’m not even sure I can fit them where they would need to go.
Components: Avionixx AXA 400.2 (2 x 125W) – $185
Sub: Avionixx AXA 400.2 (1 x 400W) – $185
Components: PPI PCX-2125 (2 x 125W) – $209
Sub: PPI PCX-280 (1 x 320W) – $139
Components: Zapco iForce I-450 (2 x 180W) – $199
Sub: Zapco iForce I-2100 (1 x 350W) – $199
Components: Orion 4002 (2 x 150W) – $229
Sub: Orion 3002 (1 x 300W) – $189
Well.. if you want to save some cash, go to thezeb.com and buy two profile amps. The CA600 will give you 150w RMS x 2 @ 4 ohms for your comps.
You will be able to find a monoblock amp to run your sub as well. The CA600M I believe will give you 420w RMS @ 2 ohms. I'm not sure the ohm rating on that sub, but you should be able to find something from profile for no problem. And, around $100 per amp SHIPPED, you'll be closer to the $200 mark.
I personally have run profile amps, and I like them, that's why I'm recommending them. Cheap, and really nice power. They also happen to look nice, which is important to me as well //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
T.J.
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif Go with ZAPCO.
Do you know anything about the iForce line of amps? I can't even find reviews of them on the web...
they are zapco...nuff said!! best pair, IMO, u have listed...
the profile amps, as mentioned above, could be a cheaper replacement...just don't expect them to be real close to their rated output
but i would do the zapco's first...the other three tied for second..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/moon.gif.9d317aec3339ffe7fde0638df52c628a.gif
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
265
You indicate it was installed? Why did the installer not go over the settings with you? They didn't set everything up? What is the system? Did...
Two of these in that box would work great. https://www.ctsounds.com/collections/tropoxl-subwoofers/products/tropo-xl-12
12
472
Just remembered, I have that same coaxial/comp set, BNIB, $245 shipped if you are interested. I have the matching coaxials, took these of the...
12
611
idiot
idiot
Connecticut
mrray13
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
