HELP Wiring 40 10's!!!!!!!
Got a beautiful (haha) paint sketch coming of the wiring for 16 of them that comes to 1 ohm...though once you factor all of the connections and speaker wire I would bet it would be pretty close to 2 ohms...
Shapow!
And during the series-section of the wiring I didnt show the first sub's pos and the 2nd subs negative coming down...but you get the idea
Your 3000s are two different sizes. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Very nice Paint work. It's been awhile since I've seen guys run that many woofers- especially in a SVC. Sounds somewhat old school. Post pics when you're done, if you get the impedance worked out. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Edit: BTW, there are only 30 subs in your "drawring."
lol, this isnt my build... My buddy wanted to do 4 08 TSNS 18's In his suv... And JD told me he had 40 10's forsale For CHEAP! so i said Hell Just pick those up and well figure it all out later... Thats why i ask...
I know how to wire subs.. just Not 40 of them...lol
And there SVC!!!!
Hey! //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
And there SVC!!!!
ok my fault then. well 18 subs per strapped pair is exactly 2 ohms
And there SVC!!!!
your going to end up running 32 instead of 40 just to get wiring some how what it should be
And there SVC!!!!
Yea, with 16 of them it'd be pretty smooth sailing...but without a nice number divisable by 4 like that, it's going to be kind of ugly..
And just to clarify, that paint sketch is of 16 svc 4 ohm subs, wired to "1 ohm" (it'd definitely be higher in real life) on a pair of strapped SAZ-3000's
I see 16 per strapped pair of amps (the ones along the top row represent the actual subs...as you head down the sketch it simply has the impedence of the above step...just to keep track)..
Yeah, you will most likely be fine with 40 due to impedance rise (I use the term "fine" loosely, as I'm not sure why anyone would want 40 subs in a vehicle), but you may want to play it safe and stick with the 32 if you haven't purchased them yet.
Subs have Already been Purchased and should be here tomo... We got them CHEAP!!!
So couldnt refuse... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
splitfirexxx
splitfirexxx
Macramento, CA
Pioneer~Saturn
