HELP!! Slight Buzzing from Sub!
Bumpin-dah8o8
nissan grease monkey
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif Hey there everyone, my problem that has just occured today and my sub is making a buzzing noise at low volume! I haven't had the time to check it out but Im suspecting it may be the case of a bad ground or RCA cables. If anyone has a solution for this I would greatly appreciate the help. Thanks a Bunch!
Sounds like your on the right track. Try switching the ground to a few different spots, maybe even with another amp if you have one. And try the RCA's too. Make sure that the speaker wire is in good condition and not frayed or coming into contact with anything else.
Does it buzz only when you have a bass note? Or does it buzz when the music is stopped to? If your are getting a buzz while it plays at low volume then it may be a air leak in your box. When you turn up the music you probably cant hear it since the music drowns it out.
thats what i was thinking, it happened to me around the mouting gasket on my sub. all i did was put a layer of electrical tape around the box openign, worked for me... if its not that make sure all ur walls are sealed wit some type of silicone
Thank you so very much I will make I happen an get back o you on outcome..THANKS again!!!!!
124
Nissan put Car Play in the 2018 HU. I was thinking going after market but I didn’t want to loose functionality and I prefer the stock look. Plus...
133
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
455
Bumpin-dah8o8
Bumpin-dah8o8
Honolulu, HI
davidfre21
Bobbytwonames
    Jul 24, 2024
Bobbytwonames
    Jul 24, 2024
