Help Plz...
aphinney
all of the other times i put this thread...no one really helped...maybe this time it will work..ok....what can i do to make me hit harder....box ( what about the box ??)...alt??....yellow top battery??....equalizer ??...dynamat ??....ANYTHING...is there anything i can do to my trunk to make me hit more dbs ?? like put wedges in the corners for the sound to hit off of....ANY IDEA'S i need help???thanx alot ...plz help... //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/titanic.gif.8089b7552c370bcc138aa121756d0c0b.gif
Well... depends on ur current setup. Usually people want to get louder and end up spending more than if they just bought better subs. What are you running right now? (sub/s, amp/s, box, wheres the box located, car, etc...)
ok... i am running (2) 12" punch hx2...with a power 1001bd amp..in a slot ported box...tuned to 44 hz... it is in my trunk and the subs and port are front faced... and my car is a 1992 buick regal custom..i have memphis wires...and i am running 8 ga for speaker wire and 4 ga for power and 8ga for ground
i have always found my system to be louder when they are faced outwards not toward the cabin but thats just me, i think there is a trick if you turn your a/c on when your getting metered you get higher db's also try sound deadening most of your car, oh and have your car on to so you can get higher volts and if you can rev the car so you can get more amps out of your alt.
aphinney
aphinney
in my house
aphinney
Emanuel Rodriguez
    Apr 19, 2025
Emanuel Rodriguez
    Apr 19, 2025
