help on making ported box
El_dorado
Dallas
ok hello guys, I have 2 rfd-2212dvc 4ohms punch hx2 12"
what would suite or be the best for this type of subs?
ok my dimm. in my car are 34"wide* 15height* 20depth are this ok?
fine then how many pieces of wood do I cut in what dimms?
SIDES* BACK&FRONT*TOP&BOTTOM
2x-34* 18 or 20 ? top&bottom
1x-34*13.5 for back part
2x-13.5x15.5 for sides
2x-15.75x13.5 for front part and port in middle with 2.5" wide ? and how long do I make port tuned around 29 or 35hz.
any suggs.. please help me out thanks If I'm all wrong please holla at me thanks all open ears
ok dimm. are a bit more bigger but at this point I suppose this dimm. are aok I want like 2.0 cubes. per chamber with no divider in middle or is it recommend ?, or otherwise I want the air to flow trought the middle like I posted before so will this or someone help on this thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
253
You indicate it was installed? Why did the installer not go over the settings with you? They didn't set everything up? What is the system? Did...
Two of these in that box would work great. https://www.ctsounds.com/collections/tropoxl-subwoofers/products/tropo-xl-12
12
455
Just remembered, I have that same coaxial/comp set, BNIB, $245 shipped if you are interested. I have the matching coaxials, took these of the...
12
606
El_dorado
El_dorado
Dallas
El_dorado
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
