PhatalOne
I have about 44" in width and 15" in height to work with in my trunk and it is about 40" deep. My problem is that I bought two Adire Shivas and they are totally different from my old Pioneer Premier SPL woofers, so I am designing a new box for them. I have read Adire's home audio box designs that the box should be about 3cu. ft. and vented to about 20 or 22hz. They also have the woofer firing downward so it has an increased Xmax. My only problem is that their stock designs will not fit in my car and so I need to custom build something.
Would any of the experienced members be able to help me out with a design?
I really want these to sound good and my knowledge on the type of enclosure I'm going to build is limited.
Here are the parameters for the Shiva:
Re 2.9 ohms
Le 2.12 mH
Qms 6.5
Mms 125 grams
Qes 0.40
Cms 0.47 mm/N
Qts 0.38
Rms 2.54 N*s/m
Fs 21 Hz
Sd 481 cm^2
Vas 151 liters
BL 11.3
Xmax 16.6 mm one way
EBP 51
SPL 87.3 dB @ 1W/1m
No 0.37%
***If I left anything out you might need to help let me know.***
Re 2.9 ohms
Le 2.12 mH
Qms 6.5
Mms 125 grams
Qes 0.40
Cms 0.47 mm/N
Qts 0.38
Rms 2.54 N*s/m
Fs 21 Hz
Sd 481 cm^2
Vas 151 liters
BL 11.3
EBP 51
SPL 87.3 dB @ 1W/1m
No 0.37%
