I have a 600 watt 2 channel (offbrand, but what they hell) and am looking to buy another when I get another sub. Can I successfully hook 2 of these up? If so, please elaborate.
run at least a 4 gauge power wire into a 2 or higher (depending on whats needed) fuse disribution block.. they have usually at least 8 guage out to the amps. then get a disribution block..usually accept 8 gauge or larger from amp with another end larger for chasis ground....want to use same size ground as your power wire from battery. fuse blocks usually have more than 1 input also so adding a cap (or set of caps) is a snap. also look into getting your alternator beefed by at least another 20 amps (also known as rebuilt or rewound)
Getting your alt. rewound can cost anywhere from $30-100. Depends on exactly what you want or by how much it can be rewound. Audiolife might be able to help you with costs for distribution block, and so on.
depending what you get and want 100-1000 ....just depends what you want u can get good stinger stuff cheap or get high end streetwires.....he is righ about the alt anywhere between 30-150 you can go mild to almost wild
