HELP! Bass doesn't sound right
sungwei
Well I put in my Kicker L5 10" today. Was ready to hear some serious pounding bass, but really was disappointed. The sub is working as I do hear bass coming out of it, but it's not what I expected. I've heard a pair of these subs in similar sized enclosures and they pounded. I know my single won't be as loud, but it should be at least as tight sounding.
Here's some details:
-It's hooked up in series (2 ohm voice coil so 4 ohm load according to manual)
-I am powering it off the mono output of my Xtant 403a amp (I think 100 watts with 4 ohm load, maybe not enough?)
-I increased gain which helped a little, but I don't think I should need this much gain plus my Sub adjustment on my HU is a +13 out of 15 (shouldn't need to be this high I think)
-Sub was louder with lowpass filter plugged in, when removed sub was hardly noticable
Overall the bass sounds dull and not punchy. Any suggestions as to where I might have gone wrong? I know it can sound better than this. Please help me with some input. Thanks!
100 watts is drastically underpowering it. That sub needs a good 500-600 before it starts to play well. You will need to upgrade the amp. Once you do you will be pleased with the sound. Remember, trying to push an L5 with a 100 watts is like trying to tow a camper trailer with a Geo Metro. //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
I own 2 L7's and Ill give you some quick tips.......
1. 100 watts is ridiculous, U need atleast 500 RMS going to it.
2. These subs take about 2 weeks to break in, after that they will pound like a motha, this means playing it low power. It will last longer and sound better longer if your break it in.
3. Keep your low pass at 100 or you'll F it up.
4. Buy a new amp, if your tight on money just get a Clarus or something from Crutchfield.
Peace
Well What if I wire it parallel? That way it's 200 Watts RMS. I know you guys say it needs 400-500 RMS but in the manual it specifically states that the speaker peaks at 450. I would imagine that 200 should be ample. In fact my amp should be putting out more than that because at 2 ohms it's 200 watts. What I'm reading here in the manual for the L5 is that if wired in parrallel it's a 1 ohm load. That's pretty low and I didn't wire it that way to begin with cause I was worried about stability issues. Now I'm considering it. I'll be playing around with it some more today. Thanks for all the input and please add more cause it all helps.
Wait I'm sorry. Impedance? I'm not familiar with the term. It's a dual 2 ohm voicecoil. Hooked up in parallel it's a 1 ohm load and in series it's a 4 ohm load. Right now it's in series. My amp puts out 100 watts RMS at 4 ohms and 200 RMS at 2 ohms. But it doesn't say anything about one ohm.
Don't hook it up at 1ohm, that amp isn't stable at that impedance. I reccomend getting another amp. I know the instruction say it works with 50-450W but low wattage is for SQ. It seems you are looking for a little loudness so power it with 300-450W if you want it wang.
p.s. impedance is basically the resistance of a subwoofer. low impedances allow for more curent to push it.
Hmm, a bit late for that. I went ahead and rewired it to parallel. Well, it definitely sounds better and louder. I didin't want high SPL just some punch to each bass hit. I'm actually more for SQ above anything else. The set up sounds good now. But I am a bit worried if my amp will totally fry. I guess I'm just gonna have to drive around and play music for a while and check on it. If it's super hot then I will consider another amp. I really don't play at levels too loud (but I guess that's all relative) so I don't think I'm gonna overdrive anything. I will let you know. Hey if anything catches fire at least I can post some cool pictures.
sungwei
sungwei
lkj
sungwei
1aespinoza
    Jun 23, 2025
Mitchell Fosgate III
    Jun 22, 2025
