Head Unit Problems Help!
  • 2
We just got a new used truck (90 F-150 4x4) and we were installing a new head unit and we hooked up the adapters and everything no power checked fuses in truck and head unit both almost brand new. It came with no radio and it has a microphone holder for a CB so we are guessing it had a CB instead of a head unit well we don't know what is wrong with it. Could it be because the CB was put there? If so how do we fix it? If not what could be the possible problems me and my step dad have installed radios/sub's before still no idea. Help please.
Start by checking your connections. Then I would move on to verify 12v switched and 12v constant. Check your ground.if none of that is present in the harness you can always run your own switched and constant power from the fuse panel.
Okay, so basically it’s still a ground loop? But then why would the alt whine go away but the other constant whine stay Sorry I’m just pretty new...
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
431
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
588
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
kushbowls420
kushbowls420
St. Louis, MO
tommydh
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
