head unit in golfcart
ive done several golf carts ,i've installed ,radios,amps screens dvd players,but if you are just doing a radio,i would suggest you use marine speakers(for boats)well to answer your question, you will need to connect the red,and the yellow wire together,and use a toggle switch in between(so u can turn it offas you want)then the black wire is ground.as for speaker locations,up to you but make sure eto run your wires in a neat and nicely manner.i hate crapthat looks like crap.well any more questions let me know.
http://forums.caraudio.com/vb/showthread.php?t=56870
My personal install, easy, just like in a car. You don't need a special toggle switch either (if you turn it off, just like in a car, the clock won't run the battery dead, and you don't ever want it completely off unless you like losing your stereo settings every time). You do need to connect the 12V constant and 12V ignition wires together though and just run that to your battery + with ground wire too of course. Gas cart or electric? One battery (on either type of cart) should be plenty for just a regular H/U and speakers. For something serious, like amp/sub system with a lot of power, you most likely will need another battery (unless you have a gas one and the alternator can handle it, but just run an extra one in case you need it). I recommend a good deep cycle battery. For the actual wiring for amp, I described in above post how to do it the best way. You don't want it running under the cart if you do any offroading. The best place I found for the wires was in a hollow tube in the frame that goes from front to back of the golfcart. Good luck.
Well, it doubles as a property management vehicle along with being a ghetto cruising vehicle, lol. While the hitch doesn't get used much, I've used it to pull jetskis (trailer w/ 3 jetskis), a small boat, larger empty trailers, and most of the time, a small red trailer used for hauling around dirt, batteries, yard tools, etc. It does pretty good. Believe me, those mud tires are well used, and I've been in many situations where a golfcart with regular (turf) tires would have never made it out (been there). //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
jaythug
jaythug
philly
scottrc5391
BP1Fanatic
    Apr 25, 2025
BP1Fanatic
    Apr 25, 2025
