Your numbers are correct. But the power only gets used when there's a load. I would imagine that higher output alternators also have more mechanical drag, so they'll drain more HP even with no load. But the difference shouldn't be noticeable on a 5.9L motor.1 horsepower = 746 watts ... I don't know if it applies to how much loss the alternator causes, but if it does, then a 200 ampere alternator should (by that measurement) cause a loss of 3.86 horsepower ...
Then again, I'm probably wrong ...
Assuming the math is right than that can only be theoretical...no wire is 100% effecient so with a 200 ampere alternator you'll really be losing 5 horsepower. How many watts are in an ampere? Do they even convert into eachother? so...many...questions... //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif1 horsepower = 746 watts ... I don't know if it applies to how much loss the alternator causes, but if it does, then a 200 ampere alternator should (by that measurement) cause a loss of 3.86 horsepower ...
From what I can remember from physics, all units of energy can be converted into one another.Do they even convert into eachother? so...many...questions... //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
- Lost Cause
How many watts are in an ampere? Do they even convert into eachother? - Lost Cause
I'm no whiz-brain, but this is pretty simple stuff.From what I can remember from physics, all units of energy can be converted into one another.
wow that's interesting... imagine having an amp with more horsepower than your car... but it works, watts and horsepower are the same thing just different amounts of itya know, that's a funny thing. MMATS amps are rated by horsepower, not watts.
