Grounding Amp on a boat...
I would ground to the Batery. I do not know if i would ground to a gas tank being that it can explode. Especially if the gound connection would happen to create a spark. That is just my opinion.
DO NOT ground it to the gas tank. You best place is run a ground wire back to the battery. But if you look hard enough there is already a ground under the driver wheel. Depending on the boat that is. But if you have any type of lights or depth finder it is grounded. You could piggy back off that ground if you wanted too.
from my expeireence, i have found a ground strip,and or blocks under the dash just below the sterring wheel,there should be 2 there one is positive and the other is negative,all boats have these there,due to power neede to the boats ignitionswitch,and guages,good luck on your boat.
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Oh ffs...he's jumped a car twice and is now an expert on car electrical systems 🤣🤣🤣
4
I had a really hard time with my 1990 240sx. That had to have been the hardest car to wire up and install to date. The doors were something else
7
SoundsGood
SoundsGood
Barbourville, Ky
houston281
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
