got my d2's metered
Burnboy
i have 2 15'' d2s in my rsx with a jbl 1200.1 it was in a sealed box with the new termlab mics. the mic was in the standard position and i hit........143.8! im pretty supsrised, my box has a few leaks in it so im sure that i can add a few more dbs. not bad for a sealed box huh?
do you consider these good numbers?
i'm curious as to what people expect to hit db wise. like what does the number mean to you? (this calls for a new thread )
Warren, for a sealed enclosure, those are very good numbers. He can make them a little higher if he uses sound deadener (if not already done) or upgrades his battery, alt, wiring, etc.
how are those good numbers for sealed.... is it b/c the average sealed boxes have those numbers or is it that the manuf. says that those are expected numbers?
i have done some sound deadening in the hatch area, not a very good job though. Im running all stinger interconnects and 1/0 power wire. I have a grounding kit hooked up too, stock battery. I didnt charge my battery up very good though so i can squeeze a few more out with that. Also my box has a leak around the sub thats hurting a bit. Once i port these and get a second jbl 1200.1 im sure ill hit 150 easy.
I hope this proves that I can do well with a single SX ported
how much are you hitting with your 15", im thinking of getting some after the xxx's in an 8 cubic ft. box, does yours have good sq in that big box, o and i think for the 2 magnums in that sealed box that is a very reasonable score :thumbsup also how many cubic ft is your box burnboy
the box is about 4.5 cubes before displacement, not too big, also the sq is excellent event at those high volumes, it hits so precise its scarey
Burnboy
Burnboy
Kentucky
BooLeaN
Emanuel Rodriguez
    Apr 19, 2025
Emanuel Rodriguez
    Apr 19, 2025
