Glueing Amp to backseat back
Xprime4
****in' canadian
I'm fawking tired of my mb quart amp mounting problems. Seriously, that amp is the least user friendly when it comes to mounting and wiring. You need to unmount the amp to acces the wiring terminal
The mounting holes are inside the heatsink and each time i'm trying to put a screw in it, it get stuck somehow and become unsuable.
I already put a like 20$ worth of Velcro behind the amp since the backseat back is made of carpet... but it ain't strong enough, falling everytime i accelarate quick.
I bough Super glue with a Donkey on it yesturday and it doesn't seems much more solid. What kind of glue would fit my application the best? I was thinking about Epoxy but i'm not quite sure. I don't care if i rush to remove it in few years... i just want the amp to stick there and STAY there for a while.
That's the only bad side on that amp, beside that i love it alot, even if it got a pretty big footprint
cliffs: need to glue metal to carpet... "industrial strenght" glue ain't strong enough
...mine is screwed onto the back of my seat.
predrill holes (i used my dad's drill and broke the bit but ughhh he doesn't need to know about that).
It'll hold, and you can undo it if you have to...?
Gorilla Glue is the best stuff I know of (other than industrial epoxy). If it won't work for you, I simply don't know what to say. Epoxy may cause a chemical reaction and melt your carpet.
But consider other possibilities, man. Carpet isn't load bearing. The weight of the amp could possibly tear the carpet, leaving you in a worse position in the long run.
It's your ride. Do what you gotta do...
I wouldn't do that on a rental car, but hey you said it, it's mine:D
I would use Epoxy in last resort... it does feel nasty. is The donkey glue transparent btw? That wouldn't really ruin the carpet if used in small quantity
Yeah the mounting holes were working great for few years. Now, screw head got pretty much fawk'up and i had to buffer the buttom to get them out. Now, no combinaison of washer+ screw works... it just make me waste my time... I spend 2 hours on that just yesturday before thinking about glueing it
don't do it. pre drill and get some new screws.
I've looked for screw long enough in few shops without any succes
The premade hole in the heatsink are pretty much screwed... there's nothing i can do with my lacking manual skills //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
um maybe try some anchor bolts instead of some glue ?? that would work much better since u got drilled holes in there already and not having to worry about the chemicals from the glue ruining your amp . cause i know chemicals from wet caulking can ruin a sub if your not careful
Anchor bolts... where can i find that? home depot?
and how do i get them to stuck in the metal under the carpet? pre-drill hole then just screwing those in
I don't know. I've never used Donkey Glue. Most Gorilla Glue dries white. But I don't think this is a situation where a little dab will do, man. You'll more than likely have to cover the bottom of the amp with glue, and that could cause all sorts of problems.
This is a bad idea.
The HU us likley 12-15 x 4 at best so yes, using an amp will be hugely beneficial, night and day. The HU us not going to drive a sub to any...
71
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
235
251
252
Xprime4
****in' canadian
Xprime4
Quebec, Canada
Xprime4
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
