Part One - I recently took out my amp and subs to sell them but I still have an amp in my car for mids/highs. I also have a cap and crossover that are still hooked up. So everythings fine for a few days until one day I turn on my car and a CD is playing fine. I turn off the head unit for a minute and then turn it back on .. no sound. So I go to check everything out and it turns out the fuse in the mids/highs amp is blown (just a little 20amp fuse). I figure no big deal I'll check all the positive and negatives and pop in another one. Everything looks OK so I pop in another one and it blow the second in put it in. Whats going on?
Part Two - A few days later I'm installing a system in a friends car. I was putting in 2 amps (one for subs, the other for mids/highs, the same amp for mids/highs I also have with the fuse problem), subs, crossover, and cap. This was the exact set up I originally had before I took out my low amp and subs. So I'm done with everything and it's time to check it out .. No mids and highs ... I check everything out and guess what - the fuse in the mids/highs amp is blown. At this time I'm thinking this amp ***** or I completly don't know what I'm doing (which I like to think I do because I've been installing for over a year). So I check everything out and everything is perfect. The only difference between this new amp and mine is that this fuse blew right away while mine was good for a few months. After hours of checking everything I decide to check the spot where the fuse goes with a test light. Turns out, the light lit up meaning that half the fuse area was positive while the other half was negative (its supposed to be a complete positive connection). I'm completly mind boggled. Why would mine do this after a few months and his immediatly. So I put in a different amp and everything goes smooth ... Whats going on?????
