Fuse Problem
68 R/T
I Just Installed Two Ppi A600 Amps In My Truck And Wired Everything Up But Im Having Problems With The Fuses Blowing On Me.both The Amps Have There Own 60 Amp Fuses In Them.would The Problem Be With Me That I Am Running One 35 Amp Fuse At The Battery And Two 35 Amp Fuses In The Distribution Block.could The Problem Be With The Smaller Rating Fuses That Im Running Or Something Else Any Help Id Really Appreciate It.
Thanks.
Each amp needs a 60A fuse so you need a 60A for each in the distro block and a 120A under the hood. If you are blowing fuses with those values then you might have other problems but for now you are just trying to use fuses that are WAY too small.
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
754
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
68 R/T
68 R/T
TORONTO,CANADA
helotaxi
spokey9
    Jul 17, 2024
1aespinoza
    Jul 15, 2024
