Found out some cool stuff
Jim Boom
Physical Sound Waves
877
MON
Did ya all know that efficientcy on a sub woofer in decibles means? I didn't but I found out that if Subwoofer A, has 3 decible greater efficiency than Subwoofer B than subwoofer A only requires half the power of subwoofer B to get the same amout of Db.
It really does mean a whole lot when you start comparing brands since they dont all use the same methods to take this maesurment. Most brands DB efficiancy is scued and not actual.
Audiobahn's i have seen really can handle that much usually but just sound like crap doing it. lots of peeps in my town run audiobahn subs
Im not trying to challeng anyones itteligence or anything, just letting you know. I mean if I didn't know I would want to.
Efficiancy rateing would probably be more helpful if all companies used a set standard to measure it. I used to take the db rating into consideration when building a system but not anymore.
This head unit has no power antenna adapter. So the image you are getting is not coming in from the correct program. Like if you were on an AM...
Dammned good amps. I ran that series for years. I just sold my last GTQ400 last year. I still have a GTS600 left. that series will run up to 16v...
Absolutely not!!! Acetone eats everything it touches other than metal that is.. there is a reason it comes in metal containers with metal caps...
11
use the icon where it says insert image, icon. press that. How to get your pictures on your computer? Use your iPhone. Then transfer it to...
What would be your cost savings per unit having your coils wound in aluminum instead of copper? Can you quantify the efficiency (or dB) gains...
5
Jim Boom
Jim Boom
MON
phoneman
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
