Fosgate or kiker?
Devilsob
20
NY
i like them both witch one would you pic? im planning on getting 2 of eather the rockford or the kicker sub.
Rockford- Rockford Fosgate RFP4212
Sensitivity: 86 dB
RMS Power Range : 400 Watts
Peak Power Handling: 800 Watts
Impedance: 4 Ohm
Low Frequency response: 28 Hz
High Frequency Response: 200 Hz
Diameter: 12 Inch
or
Kicker- KICKER S12L7 12" 2 Ohm Solo Baric
titanium deposit cone
non-resonant aluminum basket
Santoprene rubber surround
dual 2-ohm voice coils for wiring flexibility with a compatible amp
frequency response 20-100 Hz
power range 75-750 watts RMS (375 watts per coil)
peak power handling 1,500 watts
sensitivity 87.4 dB SPL
top-mount depth 6-13/16"
sealed box volume 0.88-2.0 cubic feet
ported box volume 1.75-3.25 cubic feet
I like those rockfords. Ridge from the forums, had two of them. They wanged, sound pretty good, and took his beatin very well. I have no complaints of them what so ever. He had them in a 1.25cuft sealed each. I'm sure the kickers will suit you well too. The kickers are going to be more expensive to power though. Don't go stingy on the power you're sending those kickers.
i got a lill prob now //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i got my sub box and its circle shape, so i guess that the fosgate amps will have to do.
what does the amp have to do with the shape of the enclosure?
The L7 and Power hx2 are a better comparison. The L7 has almost twice the power handling as the punch and will get louder. out of those two i'd pick the L7
Wired to option #1 would be ideal for those subs. I have quite a few 10s. in the proper enclosure, tens can get down pretty good with the right...
10
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
3K
Devilsob
Devilsob
NY
Bumpin-dah8o8
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
