flush mount???
Depending on the thickness of the driver... You could do it a few ways, buth using a router or something simmilar...
1. On your baffle where the sub goes, use a router to cut a hole, then Rabbit a second hole around the 1st for the driver lip to sit in thus making it flush... However, you are making the baffle a lot thinner by doing it this way..
2. Cut a hole in the baffle like normal, mount the sub, then add a second baffle peice on top of that with a hole cut out for the woofer itself to fit though, making it look flush...
Hops those makes sense...
the idea i had was make a regular hole the siz of the OUTSIDE of the sub ring not the screws. then take another piece of wood and liquid nail it to the inside of the box but the piece of wood on the inside of the box would be the sub baffle.......could that work or would it be unsturdy if thats a word
Lowridin_Chevy
ridin on 16's......bling!
Lowridin_Chevy
Alabama
helotaxi
BP1Fanatic
    Apr 25, 2025
BP1Fanatic
    Apr 25, 2025
