Living in icy cold canada, I steered clear of lithium and went the heavy agm route.. Im trying to do research on proper wiring for the batteries to have a balanced discharge. I have a couple questions regarding my diagram. Tried separating it into 3 sections.
The top section separates under the hood
The bottom section the hood feeds into the truck box with the bank.
The middle section the box feeds the interior.
My questions for the "Hood"...
-got the HO alt put in. The 2nd (new) fused battery lead, does it need to be fuse for the full output of the alternator, or just for the difference from the stock fuse? I wrote it in as 150A with the question mark, but bought a fuseholder where I can bump it to 300 if required for full load from alternator.
-the top middle ground, does it need to be ran? That is outside of the scope of the big 3.
The "Box"...
-If I run the power both in and out off fused distribution blocks will the current draw be more even?
The "cabin"...
-Is it beneficial to run 3 grounds in from the 3 battery bank?
-I don't think I would have to ground to chassis doing it this way. If I still should, I only have 6 terminals in the ground block (just gonna tie the dsp and epicenter on the same, or throw them under a seat belt bolt). If I am wrong, could someone confirm? Super tight space build, and am slowly running out of room for components. Dont want to have to get a bigger block.
Batteries are oddessy extreme agms, and the voltage tune on the tacoma.
All cables are 2/0 welding cable from hood to box, switching to 1/0 ofc at first distribution blocks in cabin- had to downsize to make the amp terminals happy.
Feedback and suggestion for me are encouraged
The "Box"...
The "cabin"...
