enough to power audiobahn aw1200q's?
batsbaseball14
I know people here arnt a real big fan about audiobahn but this is all I have to work with for right now. I am in the market for a new amp and not sure what would be good to power 2 of these..they are rated at 700rms and are DVC 2 ohm operation. I was looking at a HiFonics Bx1500d but I believe it will only be giving 450w rms to each sub...i'm looking for someything to do between 500-700 rms or so at 2 ohm operation. Thanks
thanks for the quick reply...yeah they will be in a ported box...kinda new to the car audio thing. I just got informed that you cant split a monoblock amp over 2 channels lol. Because mono means 1.
Thanks alot..I'm not really wanting to spend more than 350 bucks...will I be able to run a mono amp on 2 subs if they are DVC? I have heard you can and I have heard you cant.
the people that told you you cant do it are morons, you can wire DVC subs to a mono amp
from your pm to me, please make sure you go to the wiring diagram before you get anything. If you are putting 2 2ohm subs together you can't get a 1 ohm load.
http://forums.caraudio.com/vb/showthread.php?t=31984
Look at the 2 subs at 2 ohm = 2 ohm. You are needing an amp that will feed your subs at the 2 ohm load. ps.mine is 1000 watts at 2 ohm which would give you 500 per sub ;-) hope this helps
Stock stuff was crappy, yes fronts play and I physically removed the factory amp. Also, if all 4 door speakers were running off of 4 channels how...
Not that I like shilling my own sales but I have a badass digital designs 5channel for sale in the classifieds. One of the largest available...
8
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
batsbaseball14
batsbaseball14
Mcleansville, NC
plyhammer
Bobbytwonames
    Jul 24, 2024
Bobbytwonames
    Jul 24, 2024
