eD e10o vs RE SE10
nontent
As the title suggests, I've pretty much narrowed down the sub selection to those two models.
I've got about .5 - .75 ft^3 to work with (in a slantback/hatchback), and i'm going to go with a sealed setup. The goal is about 80% SQ and 20% SPL, as i'm just looking at adding the lower frequencies i've been missing.
The amp is still a tossup, but it'll probably end up being the Hifonics BX1000D, wired for a 2ohm load (as either sub is available in a DVC 4ohm setup) giving ~500 watts to the sub.
I've heard good things about both subs, but was just looking for some opinions (if any are to be had) about differences or potential advantages to going with one sub over the other.
Thanks in advance for any comments / thoughts.
80% SQ? I would definitely choose the e10o. If you wanted more SPL and less SQ the SE10 should have more output potential, but yeah in your situation i would choose the e10o.
I am running an e12o currently and it blows away the JL12w6v2 i had before (at least to my ears) it bumps harder and sounds better.
nontent
nontent
california
LeX
Emanuel Rodriguez
    Apr 19, 2025
Emanuel Rodriguez
    Apr 19, 2025
