Dual L-ported box for JBL CS1214
  • 5
Check this out!
Appreciate dude, but this is a sealed box for only for only 1 sub. I just need to know the volume the for the box.
That was a ported box, it even says 21 square inches port area and 15 inches port length.
Your airspace is going to be a bit on the small side for pair of 12s. Doesn't JBL have box plans/specs on their website or published with the sub? Have you attempted to use WinISD? It is free software and can help you see volume and port dimensions for desired tuning.
Hello guys, i have 2 jbl cs1214 and i want to make a box for them. I'm begginer at this stage. I want a L-ported box but i don't know how to calculate the volume of it. Can you help me with a design box ?
Here are the specs of the subs: https://speakerboxlite.com/subwoofers/jbl-cs1214/specifications .
I want it accorded at ~32 hz, height 380mm , lenght 700mm, width 400mm. Thank you!
I can help you out, to whatever degree you need it. Let me know!
700
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
706
815
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
Manu
CarAudio.com Recruit
Manu
Romania
Buck
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
