dual 2 ohm wiring came out to be .5 ohm.....?
if the 2 subs are dual 2ohm coils, .5 ohm is what you would get with everything wired in parallel.
each sub is wired to 1 ohm, then wire the 2 together and its .5
you could do the each sub in serires to get 4 ohm then wire them together in parallel to get 2 ohms.
JBlaze
The Biden administration on Tuesday backed down on a controversial proposal to direct the IRS to collect additional data on every bank account...
31
7K
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
cFlatt
cFlatt
MI
78nova
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
