DSP + Powered Sub with remote
doesnt really matter.... use which ever one has the most options (slope/freq.) and is most easily accessible....or use both and stack em....example: 24db slope on amp + 24db slope on dsp = 48db slope at same frequency.....but if your just gonna use dsp then set amp the highest it will go
you can put it at 200 on the amp and anywhere from 50 to 80 or maybe even 100hz on the dsp depending where your sub blends with your mids. You'll want to play with the slopes. The 200hz on the amp is just a 2ndary buffer just in case the dsp craps itself or something.
I do the same thing with a high pass filter on my tweeter's amplifier channels even though its crossed over on the DSP, i still have a 800hz high pass cross over just in case things go wrong, no bass frequencies gets to the tweeter.
I have been fairly lucky that my hearing is still really pretty decent compared to most around me that I still usually tune by ear. Ive been doing...
15
466
353
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
386
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
bilboaudio
CarAudio.com Recruit
bilboaudio
Isle of Man
Jeffdachef
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
