DMH-130BT
Do you have power to the amp which powers the sub?
A remote turn on lead?
Why do you need a splitter?
If it's only got one (and especially if it's yellow), that is more likely a video input, so you can add a license plate camera. For subs you probably need to find an adapter or a line out converter to use a speaker signal, so you can eventually get to add an amp for your sub. Might be better to just get a new head unit with rca outputs when you figure out the cost, and what you get out of it.
I just bought this same head unit. The harness the head unit comes with has a few differ rca connections. There 2 sets for the front and rear speakers. A video input, a rear view camera input. And then a singular subwoofer output which requires a single male x dual female rca splitter. I've got all my amp wiring and head unit wiring all correctly installed, I even went as far as having my power wire on one side of my pickup and the rca cables on the other side. Anyways my amp powers on and the blue power light stays lit but there's no power whatsoever coming out of the speaker outputs going to my subwoofer? I think these head units are absolute garbage for the $300 I spent on it. I had a touchscreen dual headunit that worked better than this P.O.S
I would definitely go with the Pioneer. More features, more add on options, and 6-preouts. 2v can be bumped up with a line-driver. As...
774
I got my microwave hooked up to my stereo...the bass drop when my hot pocket is done is quite frankly breathtaking...
991
Thank you. Why would u do something like this? Play it off your iPhone. Or Blue tooth. Just off the Head unit. USB is what u used or was this...
Clear iPhone from Pioner memory, clear Pioneer from iPhone memory. Power both off, wait 30 sec or so, try reconnecting.
1. Make sure you have internet connection and go through setup in the Alexa app. 2. This for contacts? If you have them favorited on your phone...
Bonkersmommi
Bonkersmommi
HardofWhoring
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
