distribution ?'s
JaY1_322
hey yall, thanks for reading, just a quick question. I'm using a stinger non-fused T shape distribution block for my battery relocation. But really thats not the issue. All I wanna know is should I crimps some ring terminals to go into it or just use the allen bolt thing to crimp down on the bare wire? maybe a dumb question but may save alot of time, planning is everything. thanks, will post pics as soon as its done! Jason
http://www.stingerelectronics.com/web/prods/distribution.asp
this link will show you the block if you scroll down to "T" blocks!
Thanks!
The distribution block your using was not designed to use ring terminals. But stinger does make pin-style terminals that are intended for your type of block; but, they are really only good for appearance and winning points on install quality (looks cleaner).
Unless appearance is a big issue, just strip off enough insulation to fit the wire inside without exposed bare wire outside and clamp it down with the allen bolt.
JaY1_322
JaY1_322
Florida
Matador
Emanuel Rodriguez
    Apr 19, 2025
Emanuel Rodriguez
    Apr 19, 2025
