Cut a hole in my truck?
misterio
texas
I really want a loud system in my reg cab f-150 so im thinking about cutting a hole in the back of the cab and in the front of the bed and making a box kind of hang out a little on the bed of the truck, then seal it off. that way i don't have to worry about mounting depth and airspace cuz i could make the box as big as i needed it. I was thinking about buying some kind of RE sub. any thing bad about doing this to my truck? its probably been done before.
I did it to one of my trucks a long time ago. Probably the worst mistake you can do if it is a daily driver vehicle. It is heard to get a good seal to keep any water from leaking in and if you decide to have the bed perminatly attatched to the cab then the bed will not be able to twist when driving over bumps or a rough road causing the bed to slowly seperate toward the rear. It will also make the cab an bed weaker since it will have a big portion of it missing.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
656
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
9
Yeah well im a maintenance technician working 12 hr days 6 days a wk ontop of school 3 times a wk which are 4 hrs long .so ya an hr drive is hard...
misterio
misterio
texas
phoneman
Bobbytwonames
    Jul 20, 2024
Bobbytwonames
    Jul 20, 2024
