Current Audiobahn Setup Suggestions
gunter84
Okay, Tell me if this would be a Good Setup please
Subs:
2 15" AUDIOBAHN AW151T SUBWOOFERS
PHAT 2” Foam Surround
120 oz. Magnet
Non-Pressed, Non-Transfer Paper Cone
KM3 Coated Cone for Low Cone Distortion
Flame-Designed Cast Flame Basket
Multi-Connect Lug-Lock Terminals
Mounting Depth: 7 1/8”
Hole Cutout: 14”
Outer Diameter: 15 1/2”
Sensitivity: 94 dB
Frequency Response: 22-700 Hz
Amp:
AudioBahn A6004T
Class A/B MOSFET Circuitry
4 - Channel
2 Ohms Stable Stereo
4 x 75 Watts RMS
1200 Watts Max ACH Power
Air Intake Cooling Fan
S/N Ratio: > 100 dB
Variable Subsonic Filter: 20 Hz - 50 Hz
Variable High Pass Crossover (18 dB): 50 Hz - 750 Hz
Variable Low Pass Crossover (18 dB): 50 Hz - 120 Hz
Frequency Response: 10 Hz - 40 KHz (+/- 1 dB)
THD: 0.02%
Cobalt Blue Illumination
Mirror Chrome Finish
Dimensions (LxWxH): 11 7/8" x 9 7/8" x 1 7/8"
Recommended RMS Power: 650W
1300 Watt Max Power
Peak Power Handling: 1300W
Impedance: 4 ohms
Head Unit:
Kenwood KDC-X879
Full Bandwidth Power (less than 1%% THD): 22 Watts x 4
Maximum Output Power: 50 Watts x 4
Let me know please,
Mike
why don't you get different 15's... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
my opinion of the 'bahn AWT series of woofers is quite dim...
gunter84
gunter84
Dalton, GA
JimJ
Emanuel Rodriguez
    Apr 19, 2025
Emanuel Rodriguez
    Apr 19, 2025
