Flipx99
Violator of Terms
A head has nothing at all to do with car audio.Wait wat? You can't swap head units on your own? Even my dumb *** can do that. You sure you're into audios?
A head is what houses the valves over the combustion chamber to an engine. It is, quite literally, the top half of an engine. I can probably get it off, but when we get the head off, we will be replacing everything from the head gasket up...all new seals and gaskets. Also replacing the water pump and timing chain since we are in there.
You need a wi-fi connection to access the internet. I do not live nor work in a place that has one. So I'd have to drive/find a place where wi-fi works. I don't see the point of buying a $350 mp3 player when the apps don't work unless I am in a wi-fi hotspot.I didn't know you had to live in certain areas to use the touch
